Sets the severity level of messages sent to the target.
In a stack, this command is applicable only to Master and Backup nodes. You cannot run this command on standby nodes.
console | Specifies the console display. |
memory-buffer | Specifies the switch memory buffer. |
nvram | Specifies the switch NVRAM. |
primary-node | Specifies the primary node in a stack. |
backup-node | Specifies the backup node in a stack. |
session | Specifies the current session (including console display). |
syslog | Specifies a syslog target. |
all | Specifies all of the remote syslog servers. |
ipaddress | Specifies the syslog IP address. |
ipPort | Specifies the UDP port number for the syslog target. |
vr_name |
Specifies the virtual router that can reach the server IP address. Note: User-created VRs are supported only on the platforms
listed for this feature in the
Switch Engine v33.1.1 Licensing Guide
document.
local0 ... local7 | Specifies the local syslog facility. |
severity | Specifies the least severe level to send (if the keyword only is omitted). |
only | Specifies that only the specified severity level is to be sent. |
If a virtual router is not specified, VR-Mgmt is used.
This command configures the specified target with a severity level. The filter associated with the target is not affected. A message is sent to a target if the target has been enabled, the message passes the associated filter, the message is at least as severe as the configured severity level, and the message output matches the regular expression specified.
See the command show log for a detailed description of severity levels.
To see the current configuration of a target, use the following command:
show log configuration target {console | memory-buffer | nvram | primary-node | backup-node | session | syslog {ipaddress {udp-port {udp_port }}| ipPort |ipaddress tls-port {tls_port}} {vr vr_name} {[local0...local7]}}To see the current configuration of a filter, use the following command:
show log configuration filter {filter name}The following command sends log messages to the current session, that pass the current filter at a severity level of info or greater, and contain the string user5:
configure log target session severity info
The ipPort parameter was first available in ExtremeXOS 11.1.
The udp-port parameter was added in ExtremeXOS 21.1.
